Confusedman
Just finished installing the alarm at my mums house.
Fitted a Honeywell accenta mini gen4 with 2 lcd keypads, 2 odyssey X3 bellboxes, 4 honeywell PIRs and a couple of Veritas E sensors
All is great apart from just one sensor
Its a texecom impaq SC door contact and shock sensor. It works on the magnetic door contact and also the tamper but it just won't trigger on impact??
The LED indicated the impact, I can program the sensitivity no problem as well
I've set the EOL resistance to 1k for both microswitches as recommended in the info sheet
What am I missing?
Can anyone help please
Thank you
What am I missing?
its a double poled panel...
What am I missing?
Thank you
So basically no eol required put them in a nonnuse position
