Leett Posted February 23, 2021 Share Posted February 23, 2021 I am routing alarm cables to a garage and following a mains cable in conduit around the outside of the house, how far apart should I have the conduit carrying the alarm cable to avoid any problems Thanks lee Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44390-cable-routing/ Share on other sites More sharing options...
james.wilson Posted February 23, 2021 Share Posted February 23, 2021 assuming normal voltages then 300mm securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44390-cable-routing/#findComment-508855 Share on other sites More sharing options...
sixwheeledbeast Posted February 23, 2021 Share Posted February 23, 2021 I'd generally try to keep as far as possible away normally trying to keep minimum of a foot or so like JW says. BS7671 is 50mm minimum between LV and ELV, unless in it's own metallic containment. More of concern is alarm cabling being outside of the alarms protected area which is generally avoided, if you have to for a single run you need to think about protection from cable tampering. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44390-cable-routing/#findComment-508857 Share on other sites More sharing options...
Leett Posted February 23, 2021 Author Share Posted February 23, 2021 Thanks guys 300mm will not be a problem Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44390-cable-routing/#findComment-508862 Share on other sites More sharing options...
