5839 system still active when a head has been removed?
Hello guys,
I have a faulty heat detector in a 5839 HMO system (a mix of about 12 heat/smoke/call points) I've take the head off and "silenced" the fault buzzer in the downstairs panel, that comes on when a head is removed.
My question is - does the rest of the system remain active while the faulty head is off, until I can get a new one on Monday?
Thanks.
1 hour ago, Developer said:
Hello guys,
Thanks.
Not my expertise
But wouldn't it silence otherwise? System will be in fault , you can always active something to find out
Depends on what you have, if it's installed correctly then yes but you have took on the liability by removing it. You should of called your maintainer
