Need ADT Reset code for PM10
Hi I need ADT unset code, we had some basic electrical work done in house yesterday and when power was back on ADT PM10 would not set
anyone any ideas or any engineers out there that could help
thanks
mike
  • james.wilson changed the title to Need ADT Reset code for PM10
What do you mean by Unset code, your manager code should be used for unset etc
Basically it would seem we have to reset the system, by entering code, could be as you describe, however we were not given any codes when system installed
How have you been arming it etc then? It shouldnt need a engineer reset if yuo have only had the power off
We use the four digit code that was set by the engineer on installation in 2014 to both set and unset the alarm.
Since the power came back on the screen shows NOT READY
You probably just need to acknowledge the mains fail.
But if your with ADT id give them a call as your on a support contract
Thanks James, 2 problems, we cancelled the monthly support charge in June as we had never had a problem for 5 years and second, they can’t answer the phone during COVID their recorded message advises.
oh
Im sure they are answering their supported clients.
But assuming no-ones been fiddling with it you should be able to reset it with your master code.
Realistically your stuck , it probably asking for engineer reset or a seed code perhaps , so better to call ADT you will have to pay them to make it stand alone and give you all new codes as they will reset it
Otherwise bin it and get new alarm installed , which will still require maintaining
