Add new user to Pyronix Enforcer alarm
Hi, I have a new build house with a Pyronix Enforcer alarm installed but the regular Master Manager Mode (accessed via the D key) does not give me any options to add or edit users - that option seems to have been removed. I have some Pyronix key fobs already working on the system, but I wanted to add another one (as one was damaged)but don't know how to do that if the 'add/edit user' option is unavailable. I also have access to the Engineer code and can access the engineer menu, but can also not find any option there to 'add/edit users'. The company that installed the system originally charges a £95 call out fee that i would prefer to avoid if this is easy to handle myself. Does anyone have any ideas on how I can add a new key fob in these circumstances? Thanks in advance for any suggestions.
Press did then the master code
If you don't get the options to view the log, change time & date, add change user ect....
You don't have the master code
You can't change users via engineering menu
Thanks MrHappy, thanks very much for the answer. When I press D I am asked to enter my own code and when I do so I get the following options - operate user outputs, change code, review logs, walk test, siren test, dial out menu and allow engineer menu. Separately, if I enter the engineer code I get other options as well - but none of these have the ability to add or edit users. Are you saying that there is a different code that is the system master code - which is different than my personal code and the engineer code - that would allow me to add/edit users so I need to try to find out what that is and to enter that when asked to enter a code when pressing D? I think the system master code is 2222 by default but that does not work. Thanks for advising and, again, I appreciate the help!
yes looks like you have another code. Engineer cant do users you need the 'manager' code
You can change the manager code in the engineer menu under change codes have you tried the default ####
Edited by sixwheeledbeast
no codes in posts please
MrHappy and James were correct in stating that the the code I was provided with wasn't the Master Code nor the Engineer code and, when confronted by this, the company was suddenly able to produce a code that worked and which allowed me to change the Manager Master Code. They were previously insisting the situation could only be resolved by their engineer after a £95 call-out fee had been paid...I was able to resolve all of this in 5 minutes when the correct code was provided. So thanks again and I really appreciate everyone's efforts to help!
