scantronic 9600 exit timer problem
Hi all
So i've got a scantronic 9600, it's mega old i know but seems to work well enough
however last night i armed it on area B to go to bed however the exit timer didn't stop after the usual 30 seconds, it continued without stopping for a few minutes until i went back to the keypad
however once i passed the entry detector halfway down the stairs the entry timer started and it seemed to disarm fine
i managed to get it to arm again and it was fine,
so was this just a random software bug or a sign of problems to come?
  • Replies 25
  • Views 4.4k
  • sixwheeledbeast
    sixwheeledbeast
    Map7 on the zones would do the trick, now where did I park my DeLorean....   Sounds like a nice job to swap out with new controls and a smart PSU, split that detection the best way possible.
  • **edit**   take your pic any commercial control would do   the issue you'll have the amount of current drawn,   if your doing DIY & have not moved an over expanded se
  • sixwheeledbeast
    sixwheeledbeast
    All part of other companies, it's survival of the fittest in this game. Aritech = UTC Castle = Hik Menvier = Eaton
they can do odd things like the above or continue to sounder the internal alarm after you've silenced it...
they appear to play up more with age,
l'd rip it out & put something new in
well it is 30 years old according to the manual (installed 1990)
thinking about it, about 2 or 3 years ago i did have an issue with the entry timer not stopping, i think i entered walk test to stop that
once it starts acting up more frequently i'll replace it, what do you reccomend? ideally need something with at least 16 zones (all 16 are filled some with 2-3 detectors on a zone) I'd like something with zone descriptions, fire zones and a relay interface
i had a quick look at other panels tonight, and i do quite like the look of the galaxy series.....don't seem to be able to find any larger scantronic panels
you should only have 1 detector per zone/circuit
true! house is pretty large and has a lot of protection, seems the previous owner was rather paranoid as all downstairs rooms have at least 1 PIR and all windows have vibration sensors
as well as 4 i think? smoke detectors on the system
many door contacts too! 2 speakers, 2 bell boxes, 3 sound bombs (i think they're called) and an ultrasonic aritech
you should see the inside of the control panel haha
its a good level of detection, I have all external windows and doors with shock sensors and all downstairs rooms have movement sensors. All on their own circuit. 2 external sounders but proper signalling
There's an SD1 dialler hooked up to it too, looks an awful lot newer though.....obviously done a complicated way from what i've seen it uses a plug on relay interface with different outputs connected to the dialler (fire, intruder and panic)
I can't see a way to get in at all without triggering the alarm, i'm starting to suspect it was installed by an engineer who lived here as there's no recipets only the user and installation manuals and i do have the engineer code
I feel like a challenge so when the time comes i would like to give it a go in replacing the panel myself, like i said i'm very interested in the galaxy series (and i think the mk7 keypad as the newer one looks a bit tacky....same with the texecom premier)
Would using the current PIR's be reccomended? It's a mix of what i believe are racal apollo's and racal scorpio's, and in a keeping with the retro theme i'd like to keep the ultrasonic as it seems to be reliable.......the whole system has only false alarmed once (feel that was my doing though as the house has warm air heating and i left that on while out all day)
and yes i have done a vast amount of research on detector models before posting, as i didn't want to waste your time guessing what they might be
depends on the age of them by the sounds they are knocking on.
its from the era when more than 16 circuits was rare & expensive....
10 latching sensors on one zone complied
I assume there's more than 1 large steel box for the controls ?
indeed, theres an additional power supply next to the control panel
in a weird way i'd rather try and keep this going for as long as i can, it really is a lovely control panel to use and has a very nice menu interface
But as i say if the time is up then it's replacement time
