Alarmhelp Posted February 3, 2020 Share Posted February 3, 2020 (edited) Hi I changed the battery on my veritas r8 alarm as it was stuck with tamper light on following a power cut. I had hoped the new battery would get me back to normal. However, when I try to set my alarm it doesn't work. I have tried #### code to reset it but it is now stuck with number 1 to 8 solid red and the green unset button also lit. I cannot change the code either using the old code - 60 - new code - prog-reset but goes back to the 8 lights on again. Can anyone help me get it working again? Edited February 3, 2020 by sixwheeledbeast no codes please Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/ Share on other sites More sharing options...
Alarmhelp Posted February 3, 2020 Author Share Posted February 3, 2020 (edited) If u press the reset button the 8 lights go away but the unset and solid red tamper light is now on When I power down and up again last time it went off for ages and only #### reset would get it to stop. If it does this again will I enter #### reset or my own code? To silence the alarm Edited February 3, 2020 by sixwheeledbeast Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/#findComment-494810 Share on other sites More sharing options...
al-yeti Posted February 3, 2020 Share Posted February 3, 2020 5 minutes ago, Alarmhelp said: If u press the reset button the 8 lights go away but the unset and solid red tamper light is now on Cover not on properly? Or requires engineer reset? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/#findComment-494811 Share on other sites More sharing options...
Alarmhelp Posted February 3, 2020 Author Share Posted February 3, 2020 My dad replaced the cover and did the battery and seemed confident it was on OK. How do you do an engineer reset? I'm totally new to this and can find very little info about it online. Thanks so much for your help. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/#findComment-494812 Share on other sites More sharing options...
al-yeti Posted February 3, 2020 Share Posted February 3, 2020 1 minute ago, Alarmhelp said: My dad replaced the cover and did the battery and seemed confident it was on OK. How do you do an engineer reset? I'm totally new to this and can find very little info about it online. Thanks so much for your help. Try setting alarm and pressing reset again Cover has a spring behind it which might not be making contact If engineer reset , then there is a special code and you will have to call out a local engineer to do it for you perhaps If it's a locked version not sure if any were but then may mean replacing whole panel Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/#findComment-494814 Share on other sites More sharing options...
al-yeti Posted February 3, 2020 Share Posted February 3, 2020 59 minutes ago, Logan said: Engineer reset flashes the led Im suprised @al-yeti didn't say replacement. ☺ Op seemed genuine for a change Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/#findComment-494818 Share on other sites More sharing options...
sixwheeledbeast Posted February 3, 2020 Share Posted February 3, 2020 Sounds to me like there is still a tamper. Check the lid spring isn't missing and that it clicks when the lid is closed if that's the only thing that's been opened. All lights on normally means your in a menu waiting for a function and unrelated to the tamper fault while your in "day mode" Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43504-veritas-r8-battery-ac-tamper-problem/#findComment-494823 Share on other sites More sharing options...
