Flat Intercom System
Hi all, I need to quote replace an existing knackered flat intercom system, 6 flats & limited cores at the intercom so thought of using a 2 wire system.
I've used Videx in the past and rated them but age old thing client doesn't always want to pay / wants options
I would need vandal resistant intercom & its audio (no video requirement)
Any one used any other good 2 wire gear?
If so where is a good place to purchase / price up?
Thanks In advance
Thanks In advance
Standard stuff ?
https://www.tlc-direct.co.uk/Products/DE906.html
Actually that is 4 core but there are others like it
1 hour ago, al-yeti said:
Standard stuff ?
Not vandal resistant not 2 wire Imran,.
 I use door entry direct just call them tell them what you want and give them your email address, they will send you a quote 0208 621 6210
I said that lol about two wire
Door entry direct are ok but make sure it's something available elsewhere aswell , some products they stop selling for no apparent reason, maybe because they the main SRS people?
