al-yeti Posted December 4, 2019 Share Posted December 4, 2019 34 minutes ago, norman said: My carbon monoxide detector kept activating and the noise was giving me a headache so I've taken the battery out. Lol joker buy new one Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted December 4, 2019 Share Posted December 4, 2019 2 hours ago, al-yeti said: So what's the a083? A083-00-01, or A083-00-02 or A083-00-10 Flex Intellibus Ethernet Module part numbers. Quote Link to comment Share on other sites More sharing options...
tinnitus Posted December 10, 2019 Author Share Posted December 10, 2019 On 04/12/2019 at 12:20, al-yeti said: Why won't it work? That’s what Honeywell tech help told me. They said it had to be a A083-00-10. Ive bought a -10 now and I’m still struggling with it. Quote Link to comment Share on other sites More sharing options...
tinnitus Posted December 10, 2019 Author Share Posted December 10, 2019 On 04/12/2019 at 16:50, GalaxyGuy said: The E080-4 will only work on the older V1.X Flex panels. The V3 panels use the faster intellibus for comms devices and camera PIR's and it requires the A083 Ethernet module. That’s great info, how do I know what version Flex I have? I now have both Ethernet modules and I’ve connected up the -10 one but my router doesn’t see it. I’m trying to get the app up and running in my phone. All the led’s on the module are as expected and I’m not getting any faults in the keypad. Quote Link to comment Share on other sites More sharing options...
tinnitus Posted December 10, 2019 Author Share Posted December 10, 2019 On 04/12/2019 at 12:20, james.wilson said: What you trying to do with it. I don't use the flex but I'd of thought it would see it an external ethernet one on the data line Sorry for late reply, I’m trying to get the app working on my phone. Can’t even see the ip address on my laptop to ping it. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 10, 2019 Share Posted December 10, 2019 16 minutes ago, tinnitus said: That’s great info, how do I know what version Flex I have? I now have both Ethernet modules and I’ve connected up the -10 one but my router doesn’t see it. I’m trying to get the app up and running in my phone. All the led’s on the module are as expected and I’m not getting any faults in the keypad. Assuming your panel sees the ethernet card??? If you set it an IP static can you ping it I would default your router aswell Quote Link to comment Share on other sites More sharing options...
tinnitus Posted December 10, 2019 Author Share Posted December 10, 2019 (edited) I’m sure it sees it, all the led’s are fine and I’m not getting a comms error. The router doesn’t see the MAC address either so I can’t set a static ip why default the router? Edited December 10, 2019 by tinnitus Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 10, 2019 Share Posted December 10, 2019 34 minutes ago, tinnitus said: I’m sure it sees it, all the led’s are fine and I’m not getting a comms error. The router doesn’t see the MAC address either so I can’t set a static ip why default the router? You can't set an IP on the panel? And gateway or subnet? 35 minutes ago, tinnitus said: why default the router? What reason you have not to? Quote Link to comment Share on other sites More sharing options...
tinnitus Posted December 10, 2019 Author Share Posted December 10, 2019 1 hour ago, al-yeti said: You can't set an IP on the panel? And gateway or subnet? What reason you have not to? I don’t want to just do random things without reasonable justification, it’s an extra step that’s probably not required. Quote Link to comment Share on other sites More sharing options...
tinnitus Posted December 10, 2019 Author Share Posted December 10, 2019 (edited) All done guys, the virgin media super hub 3 requires you to make a rule for the MAC address and the assign the IP address. That particular page from virgin takes around 15 mins to run a script, I thought it was just not responding. I walked away and came back and it was all ready to go. Edited December 10, 2019 by tinnitus 1 Quote Link to comment Share on other sites More sharing options...
