Pro installer told me I'll never see extra pixels
  • Replies 40
  • Views 8k
  • People boats they have 4k cameras , 4k monitor with an NVR or DVR that only outputs 2mp
  • sixwheeledbeast
    sixwheeledbeast
    One issue would be the bandwidth of your network when it comes to planning out a system. If the scene is the same size then 2MP vs 4MP is double the data, double the pixel density but also double
  • I use alexa to to switch stuff on and off via  a broadlink, I can control my garage doors from alexa but I rarely do, the timing on pressing the button putting my laptop in the boot and getting in the
11 hours ago, PeterJames said:
No,  My Alexa is not connected to any of my security, unless you count that its on the same router, eventually. The Alexa talks to the broadlink, the broadlink is a ir and rf transmitter, that can switch on anything with ir or rf. I have rf light switch's and of course my garage doors are rf.  Controlling a gate or just about anything by voice is simple nowadays.
So I need one of these?
https://www.amazon.co.uk/Broadlink-Automation-Intelligent-Controller-Compatible-RMPRO/dp/B077GRV5CJ
Or presumably Alexa Echo would do the same job without Broadlink?
In practice, how does it work? Can a PIR alert or video intercom visitor automatically trigger a camera window on your TV? Does it overlay whatever channel you are watching or do you have to switch AV channels?
Quote
In theory you could use an analytic camera to trigger a wireless output which in turn tells the broadlink to change the channel of the TV to HDMI source. My recorder is plugged into a HDMI input of the TV so its a separate source (like changing from terrestrial tv to a sky box).  I control mine manually or ask Alexa to go to HDMI 2 on the tv.
Quote
To operate the gate or TV or anything by shouting at it yes you need one of those, and an echo, the echo talks to the broadlink to switch stuff on and off.
Paul Hibbert explains most of it here
There are CCTV manufacturers like Dahua and Hikvision that make doorbells and entry systems that link to the CCTV and your smart phone, it wont be long until there is an alexa skill for those too
I will be getting a Hikvision video intercom for my entrance gates. Are you saying that when Alexa eventually acquires that skill I won't need any other device…or would that only dispense with the Echo (or the Broadlink)? Sorry for being a dummy.
