Intellisense 800L keypad volume
Hi - does anyone know if it's possible to lower the volume when setting the alarm (both keypad volume when inputting the code and the exiting 'drone')?
I imagine it's actually the speaker volume you need to lower. Pot on the main control board.
iirc you cant. When I used to fit the 700l I used to fit a pot to the main board as a mod. Unless the 800l had one as std. You could put a resister in series with the speaker but that would lower the alarm volume as well
Yes, got it thank you. Bingo (still louder than I would like though)
Thanks for your help
1 hour ago, sixwheeledbeast said:
Labelled Volume?
ah different layout to i remeber on the 700l thanks
They are designed to drive two 16ohm speakers in parallel so you can work out the impedance from that
