Carlos12 Posted January 21, 2019 Share Posted January 21, 2019 I've recently got an existing installation working for a neighbour, thanks so much for your previous help! However, the only thing not working is the B setting, put code in, press B = Zone Fault 2 and the alarm makes a loud horn noise. It's fine when it's set in A setting. Any clues? I have Zone 2 as 'ER abcd' | Zone 2 is the PIR setting to be activated when coming down the stairs. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42624-scantronic-9651-zone-fault-b-setting/ Share on other sites More sharing options...
al-yeti Posted January 21, 2019 Share Posted January 21, 2019 19 minutes ago, Carlos12 said: I've recently got an existing installation working for a neighbour, thanks so much for your previous help! However, the only thing not working is the B setting, put code in, press B = Zone Fault 2 and the alarm makes a loud horn noise. It's fine when it's set in A setting. Any clues? I have Zone 2 as 'ER abcd' | Zone 2 is the PIR setting to be activated when coming down the stairs. These are a right pain for this , make it exit route , but it will activate main alarm on coming down 9651 didn't have good options for this bit the silly Billy's Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42624-scantronic-9651-zone-fault-b-setting/#findComment-482229 Share on other sites More sharing options...
Carlos12 Posted January 21, 2019 Author Share Posted January 21, 2019 (edited) Would I be OK have two exit routes? I've set the neighbours door contacts set as Exit Route already Would this allow them to have time to unset the alarm when coming down? Thanks! Edited January 21, 2019 by Carlos12 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42624-scantronic-9651-zone-fault-b-setting/#findComment-482230 Share on other sites More sharing options...
al-yeti Posted January 21, 2019 Share Posted January 21, 2019 10 minutes ago, Carlos12 said: Would I be OK have two exit routes? I've set the neighbours door contacts set as Exit Route already Would this allow them to have time to unset the alarm when coming down? Thanks! Experiment, don't you mean the doors are final exit or something like that Just wondering is that what they called you in for as in main issue? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42624-scantronic-9651-zone-fault-b-setting/#findComment-482231 Share on other sites More sharing options...
Carlos12 Posted January 21, 2019 Author Share Posted January 21, 2019 Final Exit, thats the one. I replaced the battery in PCB, and problems have arisen since. Yeah, may have to experiment. Thanks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42624-scantronic-9651-zone-fault-b-setting/#findComment-482232 Share on other sites More sharing options...
