Scantronic 9651 - Zone Fault - B Setting
I've recently got an existing installation working for a neighbour, thanks so much for your previous help!
However, the only thing not working is the B setting, put code in, press B = Zone Fault 2 and the alarm makes a loud horn noise.
It's fine when it's set in A setting.
Any clues? I have Zone 2 as 'ER abcd'   | Zone 2 is the PIR setting to be activated when coming down the stairs.
These are a right pain for this , make it exit route , but it will activate main alarm on coming down
9651 didn't have good options for this bit the silly Billy's
Would I be OK have two exit routes? I've set the neighbours door contacts set as Exit Route already
Would this allow them to have time to unset the alarm when coming down?
Thanks!
Edited by Carlos12
Thanks!
Experiment, don't you mean the doors are final exit or something like that
Just wondering is that what they called you in for as in main issue?
Final Exit, thats the one. I replaced the battery in PCB, and problems have arisen since.
Yeah, may have to experiment. Thanks.
