Gardtec 490X tamper reset
Can anyone help?
i changed the battery in my garage sensor and the system will not reset.
i have both the user and engineer codes.
keeps saying
’can’t set! Eng. anti 4814’
‘garage T!’
I thought there might have been an issue with the tamper resting, but I can hear the micro switch make, and even tried it by taping the micro switch close with the sensor cover removed.
Frustrating!!!
19 minutes ago, Kenco222 said:
i understand it can be reset by the use of the master code.
so why is it asking for engineer reset....
I presume it is asking for the eng code as that is what has been set for a reset such as tamper.
i feel the tamper is faulty
ding!
its Gardtec, simply replacing the battery & ensuring the tamper is closed  would be far too simple...
2 hours ago, Kenco222 said:
Really?
But above you said you have the engineer code? So what's issue then , or you mean you have user and master code not engineer code
