August 26, 20188 yr comment_478847 I've been asked to fit a sim dialler to a guys system and what I imagined to be simple hasn't turned out that way (very familiar to us all I suppose...). The guy has bought a sim dialler which apparently needs a positive remove from the trigger terminal to cause the unit to send out it's messages. However as said, he only has a very simple panel (optimal compact), and these are fixed as negative trigger... Is there a solution, or is it a change of dialler or panel? Cheers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42344-positive-remove-trigger-is-it-possible-on-a-simple-panel/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 26, 20188 yr comment_478848 Relay Or what is exact SIM dialler in question seems odd what your saying Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42344-positive-remove-trigger-is-it-possible-on-a-simple-panel/#findComment-478848 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 26, 20188 yr comment_478849 1 minute ago, inglishg said: I've been asked to fit a sim dialler to a guys system and what I imagined to be simple hasn't turned out that way (very familiar to us all I suppose...). The guy has bought a sim dialler which apparently needs a positive remove from the trigger terminal to cause the unit to send out it's messages. However as said, he only has a very simple panel (optimal compact), and these are fixed as negative trigger... Is there a solution, or is it a change of dialler or panel? Cheers The bell output is normally high and drops when tirggered so it could be same as saying negative applied But if what your saying is a technical issue then it's weird as positive removed can mean it doesn't want to see ov either But probably basic SIM diallers are negative applied for trigger as many diallers and should work on the belloutput for trigger Try it perhaps hope you got plenty credit on the SIM Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42344-positive-remove-trigger-is-it-possible-on-a-simple-panel/#findComment-478849 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 26, 20188 yr comment_478850 it is 12v pos removed securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42344-positive-remove-trigger-is-it-possible-on-a-simple-panel/#findComment-478850 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
