Engineer Friendly Devices
Again as I have missed a number of years and as things have changed  could I ask for feed back to which detectors, & Contacts are currently the best / easiest to fit,
FA rates are important, but being able to actually fit the damn things without the cases buckling, or not enough space to terminate the connections has to be considered
I remember when I was on the tools cringing every time the bosses introduced a new detector, because it was "cheaper"
On paper they can all tick the boxes, but its obviously some are just better built and designed, so I can try and make the guys lives easier any items / makes to consider or to avoid would be appreciated
Our target business will be grade 3
grade 3 i like Optex and Honeywell detectors. Elmdene or Knight contacts
