Hi,
I have a client wanting me to connect up a paxton net2 unit with a texecom alarm system as it should be able to unset and set the alarm on entry and exit.
The problem i have is paxton diagram is not that clear.
It says i need an momentary key switch input 2 wires this is coming off a relay (where do i wire these to on the texe?)
And also from the alarm it want a voltage free status output again 2 wires, where do they go and what colours
Seems very hard to find an answer on this considering paxton sell alot of these units!
Thanks
the from alarm pair is an open close clean switch to show the paxton if its armed or not.
the to pair will go to a zone programmed as keyswitch momentary
Register a new account
Sign in
