Galaxy High Resistance
13 hours ago, MrHappy said:
so the advantage is a high resistance fault when closed wouldn't generate a intruder signal unless it got to "tamper values"
I assume "high resistance" is x% of the circuits resistance values so 1k & 1k is quite narrow but at 4k7 & 4k7 its more forgiving ?
Chances are it will go to open value before it reaches tamper value
  • Replies 24
  • Views 12.3k
it does give early warning of contact failure
Works well if signalled on a dedicated high/low res channel as long as the customer calls an engineer before setting the system
qfa
