Funkychick Posted December 22, 2017 Share Posted December 22, 2017 Greeting from Nottingham It sure if anyone know where I can buy a bell box for a Gardtec 300 came off in a storm in June also if any one has a user manual or engineers manual I would really appreciate a copy thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41818-funkychick/ Share on other sites More sharing options...
al-yeti Posted December 22, 2017 Share Posted December 22, 2017 Any bell box will work , unless you have some kind of wireless system , I assume cable is still there You just need to open panel if you have correct codes look at bell connections and match upto new bell Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41818-funkychick/#findComment-472456 Share on other sites More sharing options...
Funkychick Posted December 22, 2017 Author Share Posted December 22, 2017 Everything works on inside no sound on outside because the storm blow off the box but no installation instructions for fitting new one would you know where I could get kne Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41818-funkychick/#findComment-472457 Share on other sites More sharing options...
al-yeti Posted December 22, 2017 Share Posted December 22, 2017 Like I said , buy any bellbox they come with instructions simple Honeywell ag6 will work Side note get an engineer to fit it for you, you could find manuals on Google , this is an old alarm you should upgrade it like you might upgrade your phone or computer Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41818-funkychick/#findComment-472458 Share on other sites More sharing options...
Funkychick Posted December 22, 2017 Author Share Posted December 22, 2017 Ok thanks for you help Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41818-funkychick/#findComment-472459 Share on other sites More sharing options...
sixwheeledbeast Posted December 22, 2017 Share Posted December 22, 2017 We do not provide installation instructions here for security reasons. If you have a wired system it is likely any wired external sounder will suit. Don't buy equipment if you are not going to DIY, I personally wouldn't install kit that someone else had bought. If you don't feel competent for the task at hand get some prices for a service check and new external sounder. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41818-funkychick/#findComment-472464 Share on other sites More sharing options...
