Galaxy GX push notifications
Only TCP port 10001 needs opened if you've opted to open a port. Other ports are outgoing.
What do you mean by 'nothing happens' ?  No push message from the app?
  • Replies 31
  • Views 8.9k
  • Not sure if that's true about the firmware version, but would need to load old firmware to validate. Its normally the module firmware  version that's the issue and not the panel. Honeywell's support i
Sorted fellas. It was only after the 5th phone call with honeywell ingot to bottom of it. I'd asked time and time again is the version on my panel ok to do what I want. They said it was. Turns out version 6.8 isn't gonna work. Need v6:94 to do it.
Thanks any way for help
Not sure if that's true about the firmware version, but would need to load old firmware to validate. Its normally the module firmware  version that's the issue and not the panel. Honeywell's support is basically a database these days!
Try the SelfMon.co.uk and virtualkeypad app. They're  likely to work and if they don't, I'll be able to tell you exactly what's going wrong as I wrote all the underlying code.
1 hour ago, Lloydy8686 said:
Gonna try this now. Is there anything I need to know or is it simple to set up
Yes,  the selfmon keypad is much better than the Honeywell version if all you need is a remote keypad
Some instructions how to set up this on a co48 v6.8 if anyone can help. The 'panel programming' on selfmon shows options I do not have. All I want to do is receive notifications and to be able to set remotely if I forget.
Is this all possible with selfmon or would I be best just going back down the secure IP4 route to custodian and forget about this
Which options are you missing?  SelfMon also works on the older G3 panels with firmware before the Dimension was even born, so it should be working with your panel. Just let me know what's missing and I will advise.
When I'm trying to programme 'heartbeat'
 I get 'Option not available'
I'll tell you what I need and hopefully you can help me
i have a galaxy48. Brand new Ethernet module installed in it
i have BT internet so can't have a static IP so neee to use DDNS
I want to connect remotely usin the VKP and also receive push notifications
