kwano888 Posted November 6, 2017 Share Posted November 6, 2017 (edited) The last couple of nights the alarm has activated and on the LCD RKP it shows the following : 1 2 3 4 5 6 7 8 0 1 F 0 0 0 0 0 What does this mean ? I would have thought it would only show '1' on the zone triggered ? What is the 'F' ? I guess it's a fault code ? All zones are in use. Zone 1 is front door, zone 2 is Hall PIR and zone 3 is rear patio shock sensor. I going to change the backup battery as a start as I checked it yesterday and it's over 5 years old. Edited November 6, 2017 by datadiffusion I have deleted the duplicate topic and identical post in Members Lounge posted 5 hours ago. One topic in one place at a time, please. This is probably the better forum though. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 6, 2017 Share Posted November 6, 2017 1 hour ago, kwano888 said: The last couple of nights the alarm has activated and on the LCD RKP it shows the following : 1 2 3 4 5 6 7 8 0 1 F 0 0 0 0 0 What does this mean ? I would have thought it would only show '1' on the zone triggered ? What is the 'F' ? I guess it's a fault code ? All zones are in use. Zone 1 is front door, zone 2 is Hall PIR and zone 3 is rear patio shock sensor. I going to change the backup battery as a start as I checked it yesterday and it's over 5 years old. Showing F on walk test? Quote Link to comment Share on other sites More sharing options...
kwano888 Posted November 6, 2017 Author Share Posted November 6, 2017 5 hours ago, al-yeti said: Showing F on walk test? No its in alarm mode. This is whats showing on the display after its disarmed. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 7, 2017 Share Posted November 7, 2017 3 hours ago, kwano888 said: No its in alarm mode. This is whats showing on the display after its disarmed. Ok so F means also an activation Zone 3 is (First alarm activated) Zone 2 is (also activated) F doesn't mean fault in this case , it means first Quote Link to comment Share on other sites More sharing options...
kwano888 Posted November 7, 2017 Author Share Posted November 7, 2017 6 hours ago, al-yeti said: Ok so F means also an activation Zone 3 is (First alarm activated) Zone 2 is (also activated) F doesn't mean fault in this case , it means first Ok that makes sense. Thanks for the clarification. I'll monitor the Viper sensor as it maybe on its way out. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 7, 2017 Share Posted November 7, 2017 If your getting the same activations , meaning both zones ,are they following the same route or sharing a common cable , perhaps there is a fault Cable damaged , mice , rats ,carpet fitter etc Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 7, 2017 Share Posted November 7, 2017 Or simply that's part of the route to get to the keypad. I.E the Hall PIR when you come from upstairs to switch the alarm off. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 7, 2017 Share Posted November 7, 2017 Via the back door? Quote Link to comment Share on other sites More sharing options...
kwano888 Posted November 7, 2017 Author Share Posted November 7, 2017 12 hours ago, al-yeti said: If your getting the same activations , meaning both zones ,are they following the same route or sharing a common cable , perhaps there is a fault Cable damaged , mice , rats ,carpet fitter etc Zones 2 and 3 are on separate cable runs. No work has been undertaken. Hope no rodents been chomping ! 10 hours ago, sixwheeledbeast said: Or simply that's part of the route to get to the keypad. I.E the Hall PIR when you come from upstairs to switch the alarm off. Spot on. Keypad is in the front hallway where the PIR is located on zone 2. Zone 3 - is on the back patio door (viper sensor). I've updated the system on it now to 'Double knock' to minimise or help false alarms. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2017 Share Posted November 8, 2017 (edited) Yes but correct as it is , the viper is triggering before the hallway that's why F is present Maybe swb means viper zone 3 is triggering and some how when you enter hallway your triggering the hallway although it should be entry zone So zone2 red herring and zone 3 is the actual problem If you get me , cos I don't lol Edited November 8, 2017 by al-yeti Quote Link to comment Share on other sites More sharing options...
