Hello
Hi all,
I joined this forum as i recently installed a Pyronix Enforcer+ system in my house, and thought i would be a good idea to be linked with people, professional or otherwise with more knowledge about alarm systems than myself.
I do have an opening question to all about my self installation.
I have a single beep from the control panel every minute or so which is intermittent throughout the day. Does anyone have any ideas what could be causing this, regards Jamie.
It's been live for 6 months with no problems so far. Friday night it started beeping for about 2hrs. Sat nothing and started again this afternoon. Forgive my ignorance but what is a service timer?...
35 minutes ago, al-yeti said:
Panel been installed a year? Is it a service timer?
shows "service required on the display" after 367 days
the beep is either something "chiming" or fault which should be visable when entering a code
I've tried to fault find as best i could, run through diagnostics menu to check batteries and signal strength as it's a wireless system and all seems good, however i will have to consult the manual a bit more. Unfortunately i have this beep every minute and it's driving me mad. I don't know if i should power down the system, remove all batteries.
does a small "c" show in the bottom rh line of the lcd ?
I'm not sure, not at home right now but will post a reply shortly, cheers...
hi
silly question do you have a standalone  battery powered smoke detector  you would be amazed how many times we have all been on a callout  only to find  its the smoke alarm battery going flat
1 hour ago, petercts said:
hi
Lol forgot about that classic ,.good reminder
