Texecom V4.00 Issues
lol yeah he was at last sss meet, gave an informative bit on rf. Most i didn't understand but he does know his stuff
  • Replies 65
  • Views 28.1k
  • - VID_20251117_103431903.mp4     worked out the box,  plugged battery in, screen froze restarted & had to force into engineering Press 1 shows 14 on the di
  • I hear Orisec are OK...
  • AdrianMealing
    AdrianMealing
    OK boys and girls, we have done some testing and have found the following:-   There is an issue with keypads when they are right on the border of hopping, but don't. So in the tests we have
8 hours ago, norman said:
Is Adrian still at Texecom?
Yes I am
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
9 hours ago, PSE said:
All I've got connected is 1x Contact / 4x PW-W Detectors / 2x DT-W Dual Techs & 2x Wireless Keypads
Really cant see it being a range issue, Its all setup in my office now, Everything is within a 4 metre radius of the panel
This is the first time ever that I've seen the "Please wait b/f arming" in all the time installing Ricochet kit..
On Ricochet Monitor, are the keypads showing as direct connection or hopping I know its a short distance but if you have all the devices on a bench close to each other this can cause issues. The wait before arming is to do with the DT's being woken up, I suspect again issues with devices being too close together, AND maybe you have not allowed a proper mesh to establish before trying to arm. This again can cause issues.
Try separating all the devices by a greater distance, putting the expander in tamper and allowing the mesh to rebuild. Wait at least 15 minutes.
Just so you know, wireless keypads are as responsive as wired ones when they are directly communicating with the expander. When they are hopping through another device this will slow down the communication and they basically act as an arming station only.
Let us know how it goes.
amealing@texe.com
Visit Our Website
Texecom
All devices are direct, nothing is hopping.
I always leave in Ricochet commission for 25-30 minutes. The devices are scattered around now but still the same. In Ricochet monitor both keypads  are direct but showing as question marks with no information, They just show as zone 39 & 40. I'm using the latest 6.2.5.2 winter and Ricochet Monitor. There is a definite mismatch on the screens display giving conflicting information. My wired plug on keypad is perfect
I know I am asking the obvious, but I assume you defaulted the panel when powered up? and what do you mean by mismatch of information? i assume you have wired and wireless keypads next to each other and are watching the display?
Wireless keypads addressed correctly?
Disconnect the wired keypad and delete one wireless keypad, confrim devices, how does the remaining wireless keypad react, is it like a wired keypad or slow to respond?
amealing@texe.com
Visit Our Website
Texecom
I installed a kit recently without problems at set up other than not having the latest version of monitor so the keypads showed up as isolated but worked fine. Thought the reading of fobs a bit slow on set/unset though
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
I always default the panels mate, Keypads addressed as 1 & 2
Both keypads are at least 10 seconds difference on what each of the displays show.
OK and if you disconnect one wireless one then use the remaining wireless one how does it respond? as expected or too slow to use? Still have garbled messages?
amealing@texe.com
Visit Our Website
Texecom
PSE, I had the arming issue before with DT, I've found that if I go into zone setup and use the "(double reset) on each wireless zone all the way through to make sure there's no data at all on the exp before we attempt to learn anything in has always worked for me.
i had a big site that I inherited from a colleague that would just sit there waiting to arm, it boiled down to the fact that devices had not been learnt on correctly and then the receivers were not being cleared before starting again. ( I believe he was powering devices up but pressing the tamper switch as they were pairing with the exp??)
After defaulting everything and staring a fresh it was fine.
In relation to your keypad issue, I too have a new kit set up myself but with only 1 wireless rkp and it's been running fine for 3 weeks, it is very responsive (to my surprise) as I didn't have high hopes for a battery keypad but it works great.
Be interesting to see if you have any network errors logged on the system?
best of luck
Stuart
I really hate doing this, especially with a product that Ive used for many years and personally have such a high opinion of the product. But I've had enough to be honest, the wireless keypads are slow as hell, the LCD screen contrast is a joke. There is no contract setting on the wireless pads, unless you install at head height it's unreadable. The blue backlight really overpowers the text. I've just spoke to technical who said that's how they are, nothing can be done about it, only the wired have contrast adjustment.  So much for these being identical to the wired version, they are miles apart.  These need contract adjustment
Simple really, if I'm not happy to have it in my house, it damn sure won't get fitted in a customers. I've arranged with the customer to go back and replace the system with an alternative.  This kit will end up being returned.  Anyone with a requirement for them should see one working, both of these are less than 8 metres away and are just slow and useless.
