Texecom Elite 24 programming
Hallo
Can everyone help me with Texecom Premier Elite 24 and LCDLP Blue Keypad.
I have just a flat and only one Door to secure.
It`s just one NC Contact on Zone 1 connected.
How shall I programming the device?
And sorry for my bad english.
Thank you Best Regards Daniel
IMG_6520.thumb.JPG.da74e9dfa6469f26f5dc5968d0d8bfb4.JPGIMG_6521.thumb.JPG.9c82fd732fc17047e6daa11e04896826.JPG
Edited by Daniel G
Yes, you will need to make sure you programme the zone on the panel for Normally Closed.
Assuming this is the entry door it will need to be Entry/Exit type also.
ok.I do have this two settings.
What about Zone Atributes.
Do I need the them?
Thank you very much!
I forgot the Confirm Device step.
We have a idiom in Germany: Everyone who can read have an advantage..
I have another Question
I connect the normally close contact without tamper now on the LCDP Zone 1
Zone Wiring Setting is: Normally Closed
The system don't recognize the contact.
In Menue View Zone Status also not.
How can I activate Zone 1 at the LCDP
Or is the wiring wrong?
you need to link out T and connect to just the A connections
Keypad zones have to be mapped. This is Keypad number 1 so Zone 1 on Keypad need mapping to a zone between 1-24.
You set the zone wiring type per zone as well.
Thank you for you help!!!
The Keypad was not mapped. The system works fine now!
Have a nice evening!
Daniel
