16 minutes ago, norman said:
Your checks are commendable but too comprehensive imo, I'd expect those on a monitored takeover.
Discuss the history of any issues, check bells, batteries (Inc current and charge) , induced ac at a push, walk test Inc pa's, cct resistance,
Thanks Norman. We will scale it back and knock off earlier!
12 minutes ago, Dwm90 said:
This is mostly the initial take over and first service I'm referring to and most of the companies round here use dp.  All our new Installs are EOL unless its really low risk sheds etc but our usual way is to speak to customer ask about any problems and look at what paper work they have which is usually a zone list in the user guide and then we proceed to do all the checks on my first post.
So its a takeover or a service?
I accept that but I thought the question was about a service not a takeover.
I reakon an hour to do a takeover is speedy depending on the panel
Or fit in more service calls per day.
You're welcome.
Register a new account
Sign in
