Scanny i-on 16
Evening guys, any one got manuals for the I-on 16 pretty please?, typical, got every other begged.. ...tia, Rich.
Bear in mind (as you prob kno) the 'Installer Guide' is basically a slim pamphlet with a list of what the terminal blocks do, on it.
Any info of substance is in the generic Engineering Manual for the whole range.
Also as I'm sure you know, the 16 is 'stuck' with the firmware it came with, and isn't updatable, unlike the rest of the range. So make sure the features you're reading about apply to your model!
Engineering Manual V4.pdf
Installer Guide i-On 16 (Issue 9).pdf
Edited by datadiffusion
cheers for that DD, appreciated mate, it's not my panel of choice, looking at one for a pal tomorrow, so until I get my hands on it!....
Fair enough, tbh the 16 is dire as the range goes :(
Although at least if you have a new enough one, you can get 2 wired zones via a keypad.
Cos you ripped it out for an Optima?
