Adpro and vivotek ip cameras
Hi guys I've been installing Ip cameras for a while now and all been connected thru Adpro without any problem.
But this time what it is all seems to be working fine apart from that twice a day some of the cameras got no video for 3-4 seconds.
Switches I'm using are trendnet 80h with poe. All 8 port switches but maximum 5 cameras in one switch.
Does anyone come across of that before?
Cables tested, cameras tested, switches tested.
What FPS are the cameras set at and what is the expected FPS at the Adpro? Is this a dedicated network or is it part of an existing Lan?
Thank you for quick response.
Forgot to mention it.
Stream1 is 1280x720 8fps
Stream3 is 640x480 5fps
Same Adpro is expecting to be.
Network is dedicated.
are they using a native driver?
you should be using the recommended image size and fps then. Bit you could try setting your camera at a lower fps rate than the Adpro.
