Info on Viper circuit false alarm.
My guess would be that you have solved the problem, but finding a credible cause will stop you investigating further, so I dont blame you for using caution. That said I am 99% sure it is most likely the cause.
  • 2 weeks later...
  • Replies 31
  • Views 9.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Normally a competent alarm engineer would  measure the circuits,   low Ohms between each pair of cables, high Ohms between cables which ain't paired.   With the system running on b
  • PeterJames
    PeterJames
    There are several things that could be causing your problem as follows:   1. Auxiliary power failing. Loose fuse or poor connection at the panel down powering the vipers will cause the circu
UPDATE: the alarm has now been tested fully for over two weeks - four days at full set -  and all is well. Once again a big thank you to all who helped me. It was very much appreciated.
