June 1, 201610 yr comment_446988 greetings, i have to quote to replace a menvier control panel which was once on redcare but bells only now. the keypad appears to be exactly the same as a mevier m800 series panel, there is what looks like one of menviers node expanders next to the panel and the zone list is numbered as zones 0001 to 0006 which i assume is wired off the panel and zones 2011 to 2018 which i assume are zones wired from the expander next to the panel. i have not opened the panel. can i also assume that this is not an id biscuit panel? it would be handy to assertain this before i quote to fit with a standard double pole eol panel. i have attached a library picture of keypad and node. thanks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40191-menvier-m800-panel/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 1, 201610 yr comment_447003 Never assume it certainly could be iD Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40191-menvier-m800-panel/#findComment-447003 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 5, 20169 yr Author comment_447088 well this is why im here asking these questions and showing photos of the equipment! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40191-menvier-m800-panel/#findComment-447088 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 5, 20169 yr comment_447089 40 minutes ago, jjohn said: and showing photos of the equipment! I'd assume the plastic box was same for all the supported nodes ? What controls do you intend to put in its place ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40191-menvier-m800-panel/#findComment-447089 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 5, 20169 yr comment_447090 hi the problem is menvier used the node box for ever thing for many years from a six zone expander to radio node to x node or m node and if the panel box is full size they used that for years to Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40191-menvier-m800-panel/#findComment-447090 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
