greetings, i have to quote to replace a menvier control panel which was once on redcare but bells only now. the keypad appears to be exactly the same as a mevier m800 series panel, there is what looks like one of menviers node expanders next to the panel and the zone list is numbered as zones 0001 to 0006 which i assume is wired off the panel and zones 2011 to 2018 which i assume are zones wired from the expander next to the panel. i have not opened the panel. can i also assume that this is not an id biscuit panel? it would be handy to assertain this before i quote to fit with a standard double pole eol panel. i have attached a library picture of keypad and node. thanks.
hi
the problem is menvier  used the node box for ever thing for many years  from a six zone expander to radio node  to x node or m node and if the panel  box is full size  they used that for years to
Register a new account
Sign in
