Prosys 128
Does anyone know how to connect an Ethernet module to a Risco Prosys 128, which uses a Red Care Interface I have raised this issue with Risco Technical but they could not answer this one.
Edited by Carl
spelling error
do they make an ip module for the prosys?
Just attempted to upload the ACM manual to the download section, never used it mind.
Yes they do, I checked, I need to use Upload / Download Software and I can't use a modem as the only modem Risco specify are no longer made. So having to go down the IP Route.
Thanks for your comments, I really appreciate your time in looking at this one
if tech can't help you not sure what you can do, or maybe they are misunderstanding what your trying to achieve with what equipment.
You have the manual for the unit and the panel, where is the problem specifically?
Not a panel we have used before but I think Webway support UDL on these panels.
