aka_alex Posted April 2, 2016 Share Posted April 2, 2016 Hi all, I have a Europlex Signet 100 installed and have just added a GSM module to the system. When an alarm is activated, notification is sent via GSM to my phone and it all seems to be working fine. When I try to send a command to my system from my phone via text eg to carry out a full set or to view the system status, nothing happens. according to my phone, the text was delivered but nothing happens on the system. What am I doing wrong with this? Have I missed a setting somewhere along the line?. My system firmware is v 1.0.0 and the firmware version on GSM module is v 1.1 SMS Auth is set to caller id only. Any Suggestions would be appreciated. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/ Share on other sites More sharing options...
james.wilson Posted April 2, 2016 Share Posted April 2, 2016 Does it have an Ethernet port on it. If so you may be able to upgrade it to 3.6.x and use the cloud app. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443870 Share on other sites More sharing options...
aka_alex Posted April 2, 2016 Author Share Posted April 2, 2016 No, it does not have an Ethernet Port unfortunately. I'm stuck with the GSM option. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443871 Share on other sites More sharing options...
Rulland Posted April 2, 2016 Share Posted April 2, 2016 I assume that sms auth only allows texts from set numbers to make any changes, I also assume that you must therefore program allowed numbers into the system, if this is the case have you done it?. I don't know the panel though so just guessing. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443874 Share on other sites More sharing options...
aka_alex Posted April 2, 2016 Author Share Posted April 2, 2016 Hi Rulland, you assume correctly and yes, I have programmed allowed numbers into the system. I have done everything mentioned in the installation manual but it will not allow texts from my phone. When alarm is activated, I receive a text informing me of the alarm and what sensor was activated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443880 Share on other sites More sharing options...
james.wilson Posted April 2, 2016 Share Posted April 2, 2016 Have you tried +44 instead of 0? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443885 Share on other sites More sharing options...
aka_alex Posted April 3, 2016 Author Share Posted April 3, 2016 james.wilson, thanks for reply. Yes, I have used the country code when entering my mobile number, still hasn't made any difference. I must have missed a setting somewhere along the line, will go through it all again later today and see if I have. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443940 Share on other sites More sharing options...
jnealon Posted April 3, 2016 Share Posted April 3, 2016 Are you using the code + command eg 1234 ssta. GSM pin set up correctly Definitely a setting wrong somewhere www.realsecurity.ie Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39955-europlex-signet-100-gsm-question/#findComment-443941 Share on other sites More sharing options...
