Galaxy G2-20 Battery Problem
Plenty g2 floating about with faults , even brand new , poor manufacturing in recent times I would say
How far is cable from keypad to panel , if cable is hidden try and fly wire from panel to keypad just to rule that out if you get me
  • Replies 28
  • Views 8k
  • Created
  • Last Reply
Board is doing this without any load only ac power on and no battery connected, I am measuring 6v dc from aux o/p's.  Have a g2-44 and two g2-20's all with the same symptoms,
I blew the aux fuse on 2 of these boards prior to this happening - this of course maybe related to my problem, old age and forgetting to power down unit prior to pulling a cable causing +ve and -ve to short out. But one of the boards came from eBay which measuried this way before any load put on it.
This isn't just happening to me I guess?!
Picture of where your taking measurements, as your saying three boards all with same problem
43 minutes ago, al-yeti said:
Also what did you do to blow the fuse
Just above the RS485 terminals there are 4 +/- aux outputs (these have red and black wires in the picture), the fuse blew in effect by shorting these terminals (touching red and black wires at a PIR).
remove the speaker wires and check again
www.nova-security.co.uk
www.nsiapproved.co.uk
Novaman, all wires have been disconnected and only ac power connected and I measure 6v dc at aux +/-. Why do you suspect the speaker wire(s)? I did at one point but only because I pulled them by mistake quite hard from the my loft. I haven't checked them for short between or to ground as yet but as I say all wires have been disconnected other than ac supply and tamper although this is not to say this was the root of my problem to begin with; that is if you know something that I do not....?
Thanks for all your help, it's much appreciated.
Just to clarify the picture is from a few days ago, I no longer have it all wired up.
One more thing, excuse my ignorance, but I assume you mean the internal speaker wire not the Bell box (SAB) wiring, right? This is brown in the photograph and also a positive component which is connected to one of the +ve aux terminals which is an orange wire in my case, but I don't think you can see that from the picture.
