Photos of alarm system installation
Guest mike2004
Second that, one of my pet hates seeing T&E connection to a spur, corner cutting in my book.
28107[/snapback]
What's the problem? It's hardly cutting corners. It's harder to work with, more expensive and needs sleeving for the earth.
In my view, flex is cutting corners. Penny pinching, it's the minimum you can get away with and less expensive.
Nice to see a well installed bit of T&E to a control panel, Sheathing stripped back to the grommet, earth sleeving covering full CPC, nicely installed with a little bend in it.
:wub:
If you don't know......ask.
Guest mike2004
I'm using twin & earth (2.5mm) for the run from the consumer unit to the fused connection unit (pictured above), and flex from the connection unit to the panel. The only advantage of T&E over flex is its load-capacity, and given that the connection unit will have a 2 or 3 amp fuse, I considered the choice of cable from it to the panel to be more convenience-driven!
(To RICHL) - luckily not - the lead pipe in question is a redundant old pipe (now disconnected) which used to carry gas to a fireplace.
Here's my latest pic - the cable to the keypad (in the downstairs hallway, near the front door).
Having a cellar will make some of the cable runs quite convenient. Just had to raggle the cable down, and form a chase up to the intended site of the keypad.
The current intended specification is as follows (using 8-core cable throughout):
Zone 1: Front door contact
Zone 2: Downstairs hall PIR (in entry zone)
Zone 3: Lounge and dining room PIRs
Zone 4: Upstairs hall PIR
Zones 5,6,7: Other door/window contacts or vipers as necessary (not yet decided)
Zone 8: PA button in master bedroom
Outputs: Bellbox X 2 (2 of front, side and back of house - not decided yet)
Outputs: Sound bomb in downstairs hallway
Outputs: Relay output to switch on the light in the downstairs hallway during entry/exit and alarm stages, in order to provide light for us when entering/leaving at night, and to illuminate an intruder.
Any comments/tips are very welcome!
Mike
Guest mike2004
Haven't done it very often, but like to use capping when I do. Is that not a requirement for buried cabling to have some form of protection?
28176[/snapback]
Only a requirement for mains cable, and then it must be adequate protection ie earthed galvanised steel (unless it is in a specified area, namely horizontally or vertically from a visible mains item (such as a switch or socket) or within around 7cm (I forget the exact number) from top or bottom of the wall.
You could use one of the 2 zones on the control panel for the door contact. This would free up a zone to split up your zone 3 dining/lounge.
