Hello all, I have an accenta g4 system up and running.  However when I try and wire a second keypad to the panel (have checked the wiring about a million times!) at power up the keypads just show a version information and accept no button pushes? Alarm also going off.  Any ideas? Manual says I can have multiple, so a bit lost !!   Thanks in advance for any ideas...
Is it the LCD version keypads ? I beleieve the LCD will work on some of those panels but display info and have certain funstions only and if you have a panel that needs the led keypad you must have one of those to see what your doing , at least it's what I saw on one system
Register a new account
Sign in
