broda02 Posted January 19, 2016 Share Posted January 19, 2016 Hello all, I have an accenta g4 system up and running. However when I try and wire a second keypad to the panel (have checked the wiring about a million times!) at power up the keypads just show a version information and accept no button pushes? Alarm also going off. Any ideas? Manual says I can have multiple, so a bit lost !! Thanks in advance for any ideas... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39606-accenta-g4-multi-keypads/ Share on other sites More sharing options...
norman Posted January 19, 2016 Share Posted January 19, 2016 Hello, not familiar with the panel but I'd assume they are addressed, have you set the addresses correctly? Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39606-accenta-g4-multi-keypads/#findComment-438681 Share on other sites More sharing options...
broda02 Posted January 19, 2016 Author Share Posted January 19, 2016 No addresses. You wire the tamper in series on all the panels and the rest parallel connections (sound, + - Comm) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39606-accenta-g4-multi-keypads/#findComment-438682 Share on other sites More sharing options...
norman Posted January 19, 2016 Share Posted January 19, 2016 Have you swapped keypads to prove it's not a faulty one? Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39606-accenta-g4-multi-keypads/#findComment-438684 Share on other sites More sharing options...
broda02 Posted January 19, 2016 Author Share Posted January 19, 2016 Yes, I haved. Tried both as the single keypad and bot work. Tried a fob one also and same failure.. Thanks for the response Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39606-accenta-g4-multi-keypads/#findComment-438685 Share on other sites More sharing options...
al-yeti Posted January 19, 2016 Share Posted January 19, 2016 Is it the LCD version keypads ? I beleieve the LCD will work on some of those panels but display info and have certain funstions only and if you have a panel that needs the led keypad you must have one of those to see what your doing , at least it's what I saw on one system Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39606-accenta-g4-multi-keypads/#findComment-438688 Share on other sites More sharing options...
