Steven_W Posted November 23, 2015 Share Posted November 23, 2015 I put an analogue DVR in my office a while ago and only accessed it via the mobile apps or web, never looking at it directly on a monitor. Well we've needed to hook it up to a monitor via bog standard VGA and the image is "shifted" to the left. All 4 cams are showing fine but the overall image is cut off. When I first set this up I had it connected to HDMI and it was OK but need the VGA output as just using old spare monitors. I've looked right through the settings on the DVR and there is nothing to change the resolution or screen position. Any ideas? Ta. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/ Share on other sites More sharing options...
james.wilson Posted November 23, 2015 Share Posted November 23, 2015 its the monitor sync that needs adjusting securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/#findComment-435426 Share on other sites More sharing options...
Adi Posted November 23, 2015 Share Posted November 23, 2015 Id of thought there would have been some display settings, what tat is it. I really can't be ar**** with it anymore. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/#findComment-435445 Share on other sites More sharing options...
Steven_W Posted November 25, 2015 Author Share Posted November 25, 2015 I've tried the monitor adjustment, that was the first thing I looked at... The setup is as follows: 5m VGA to a 2 way high bandwidth VGA powered splitter, then 1m cable to my monitor & 20m VGA to monitor 2. I thought at first that it was the splitter causing the problem, so I connected directly to the monitor... same problem. As I didn't run a mouse extension cable in, the only other thing I can think of is that there are settings within the DVR that can only be shown while accessing the menu from the DVR GUI rather than over the LAN. I've had that before on other DVRs. It's not the end of the world if I can't solve it, it's just annoying! Thanks fellers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/#findComment-435603 Share on other sites More sharing options...
datadiffusion Posted November 25, 2015 Share Posted November 25, 2015 (edited) I had a slightly old (but still at least mid 2000s era) Fujitsu TFT that simply won't connect to any DVRs Just states 'out of range' on the OSD. Binned now anyway. Edited November 25, 2015 by datadiffusion So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/#findComment-435667 Share on other sites More sharing options...
Alisdair Keating Posted November 26, 2015 Share Posted November 26, 2015 (edited) Just a thought. Have you checked the output for the dvr is set to pal and not ntsc. Not sure if it would cause this problem but I have known it cause other image related issues. Edited November 26, 2015 by Alisdair Keating Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/#findComment-435746 Share on other sites More sharing options...
Steven_W Posted November 27, 2015 Author Share Posted November 27, 2015 OK, so once I plugged a mouse in I could access the resolution menu which is not available through the web browser, changed the resolution & restarted, all is now well... hope this thread can help someone! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39404-dvr-outputting-dodgy-video-via-vga/#findComment-435795 Share on other sites More sharing options...
