  • 2 weeks later...
Just as a test measure for the bell outputs, if I close loop sab with the terminal to the right with the black wire, with the 4k7 resistor in series this should allow me to test the +/- bell outputs?
Tells you on the PCB
Earth
AC In
12v AUX
EXT Sounder
Int Sounder
Hi thanks, yeah understand this terminal, its just the sab, and the other just need to know iun order to test it can i just close loop it or will I need the resistor in series with the close loop if you get me
Also I've noticed theres no strobe, thinking it may be a gd idea to advise them to get a new control panel, sounder, and new detectors and keep existing door contacts as apparently these were changed recently, just the only other option in my eyes is to use the existing sounder without the battery and close loop the tamper, or to put a new sounder on which has a strobe which doesn't operate
Edited by matt6697
resistor in series
Why dont you just set the system and see if the bell goes off once triggered,
It's just I've got a job with this panel, everything seems to be working fine apart from the external sounder, noticed last guy wrote down the ext sounder battery was dead, looks like hes also close looped the tamper, & cable used is only a 4 core one!
tested system, with power disconnect, and battery disconnect ext sounder doesn't work on either
SAB battery failure ?
www.nova-security.co.uk
www.nsiapproved.co.uk
Register a new account
Sign in
