dwdave Posted July 26, 2015 Author Share Posted July 26, 2015 Its been fine on 9600 but I will dig out the DipSwitch settings and drop it to 1200. Quote 'till the next question ... Link to comment Share on other sites More sharing options...
dwdave Posted July 26, 2015 Author Share Posted July 26, 2015 Well I'll be. 1200 it is. Good connections on both PC's using Serial & USB>Serial. Yet it worked fine on 9600 for a few weeks. Thank you so much. Happy Dave. Quote 'till the next question ... Link to comment Share on other sites More sharing options...
GalaxyGuy Posted July 26, 2015 Share Posted July 26, 2015 Galguy : Ive never programmed and I dont know what SIA3 or TTL is. This is my 1st Pi project more than just building a media player. Also, I cant go from the Pi Serial Port as the galaxy doesnt have a serial port - not that works anyway. Hence why it might be overkill just to read some pins, but its basic, which is what I understand! For now though, I think that the RS232 board has had it and its an expensive upgrade to a Dimesion 96 when I bring in the associated keypads, RSS etc just to get serial functionality back. Okay, I see that you now have a serial port. I agree after re-reading your posts that it's probably too advanced for you to be writing / modifying the SIA protocol based code. You'll still need to know how to convert levels on the RIO when connecting to the Pi. I think there are links on the older classic panels that you can cut in order to go open collector. It's that or you need to convert down to 3.3V. DD, I didn't look at the new Pi, as the beagle black is a better solution. I just haven't had time to complete the code for the companion processors to emulate the ethernet module. Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted July 26, 2015 Share Posted July 26, 2015 Yet it worked fine on 9600 for a few weeks. It struggled...... Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
9651 Posted July 27, 2015 Share Posted July 27, 2015 9600? Quote Link to comment Share on other sites More sharing options...
