datadiffusion Posted June 15, 2015 Share Posted June 15, 2015 This is what I mean. Command 61, option 1 Exactly, so you would potentially be making the landing pir zone, often the only upstairs protection, and often the first pir physically located after the entry exit zone proper an entry route zone just to accomodate the above option.In the typical UK house setup, this means on full set, someone can boot the front door in and head on up the stairs scot free whilst the entry timer chimes. Not for me chef. Dont get me wrong it would work, but its a huge failing of this panel and the ion that you dont have a freer hand in changing response based on set level. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-420983 Share on other sites More sharing options...
Bactongas Posted June 15, 2015 Author Share Posted June 15, 2015 Thank you all for your replies, most of which went straight over my head..... Sorry. But TIMMO 61.... looking at comm 61.. The setting was 0, and I've now changed it to 1. Which seems to make sense. As the alarm gave you no time to put the unset code in before it armed and sounded, I work away and the misses uses it as a safety thing and it was just a pain in the morning that she wakes the whole close with the bell sounding, hopefully now she will have 45 secs to disarm. Will test and report. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421006 Share on other sites More sharing options...
Bactongas Posted June 16, 2015 Author Share Posted June 16, 2015 Ok sadly alarm still sounds as soon as you enter the area... There is no deactivate time for the B set. More help???? Mark Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421024 Share on other sites More sharing options...
Bactongas Posted June 16, 2015 Author Share Posted June 16, 2015 The pir picking up on entry is zone 4. And nothing I do allows an entry delay, just like coming in the front door.. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421026 Share on other sites More sharing options...
datadiffusion Posted June 16, 2015 Share Posted June 16, 2015 The pir picking up on entry is zone 4. And nothing I do allows an entry delay, just like coming in the front door.. This is the issue I refer to above. You will have to set the Zone 4 type to 'Entry Route' to make the '61' feature work. The downside is that then, as I say, a burglar can enter the house through the front door and then on to Zone 4 without the alarm sounding, when the alarm is fully set (i.e 'A' set) I would personally retain a higher amount of security for the full set, and simply remove Zone 4 from Part Set B by going into the programming menu for Zone B type and pressing the 'b' button to flag it as removed in Part set B However, I would seek advice before potentially lessening the security of your system. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421039 Share on other sites More sharing options...
al-yeti Posted June 16, 2015 Share Posted June 16, 2015 But it would also mean when part set there is no reminder that alarm is set if they deviate off into another room Can the zones act differently if part set ? Doc? Galaxy g2 / hkc you can tell the zones to behave differently in part set modes ie they become as you entry/exit Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421048 Share on other sites More sharing options...
datadiffusion Posted June 16, 2015 Share Posted June 16, 2015 But it would also mean when part set there is no reminder that alarm is set if they deviate off into another room Can the zones act differently if part set ? Doc? Galaxy g2 / hkc you can tell the zones to behave differently in part set modes ie they become as you entry/exit I know, but making X number of zones Entry Route is the only way to achieve this Annoyingly, there is an option (60 / 62?) to make Final Exit = Normal Alarm in part, but NOT the opposite which quite frankly would have been more useful. If I was already in the house I would just as likely be woken up by the EE timer tones as the alarm itself, but it would still prevent full alarms from AM accidental triggering. No, they can't, other than by the very narrow 'feature 61' and this is a major failing of this and the ion So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421054 Share on other sites More sharing options...
Nova-Security Posted June 16, 2015 Share Posted June 16, 2015 Op hasn't said what he actually has though That would be good. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421056 Share on other sites More sharing options...
datadiffusion Posted June 16, 2015 Share Posted June 16, 2015 Agreed but lets take a guess its a top of stairs PIR? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421058 Share on other sites More sharing options...
Nova-Security Posted June 16, 2015 Share Posted June 16, 2015 Yep Buts what he got in the hallway downstairs and on the FE or is the PIR in the hallway the FE or has he anything. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38637-scantronic-9651/page/2/#findComment-421060 Share on other sites More sharing options...
