zurrieq Posted April 2, 2011 Author Share Posted April 2, 2011 (edited) Zip7 here. Works fine, no problems What is it? I installed 7-zip. Can open the downloaded zip file but I can only see CobLoad as 1 file inside the archive. Doubleclicking that file shows the .exe and .cob files. Edited April 2, 2011 by zurrieq Quote Link to comment Share on other sites More sharing options...
zurrieq Posted April 2, 2011 Author Share Posted April 2, 2011 I installed 7-zip. Can open the downloaded zip file but I can only see CobLoad as 1 file inside the archive. Doubleclicking that file shows the .exe and .cob files. I get this error: Quote Link to comment Share on other sites More sharing options...
zurrieq Posted April 2, 2011 Author Share Posted April 2, 2011 I opted for DOS: tftp -i xxx.xxx.xxx.xxx PUT Web1.cob WEB1 which worked. In fact I can now see the Menu on the side. I enter the engineering password. When I click Online Keypad, I get the keypad indicating "Reading.......", then I get no "Access with System". Then I click something else such as System Zone Status or Event Log and I get a System Alerts on the keypad - Areas need reset and Com 1 Fault. Trid this a number of times and always get the same issue. Do I need to enable something? Quote Link to comment Share on other sites More sharing options...
reidy Posted April 2, 2011 Share Posted April 2, 2011 TFTP isn't enabled by default in Windows 7, this should help http://www.andrels.com/wp-en_US/index.php/2009/12/how-to-enable-telnet-and-tftp-client-on-windows-7/ Quote Hey Ho, Lets Go Link to comment Share on other sites More sharing options...
zurrieq Posted April 2, 2011 Author Share Posted April 2, 2011 TFTP isn't enabled by default in Windows 7, this should help http://www.andrels.com/wp-en_US/index.php/2009/12/how-to-enable-telnet-and-tftp-client-on-windows-7/ I had done that but still did not work. Anyways, then I installed it through dos prompt was was quite simple. The problems is that the code is still not working as per above post. Any ideas? Quote Link to comment Share on other sites More sharing options...
reidy Posted April 2, 2011 Share Posted April 2, 2011 (edited) Apologies, I didn't read all of your post Try setting a UDL password and using that, when I tried that, it does sort of work but usually results in crashing my ComIP module causing a com port fault Edited April 2, 2011 by reidy Quote Hey Ho, Lets Go Link to comment Share on other sites More sharing options...
zurrieq Posted April 2, 2011 Author Share Posted April 2, 2011 Apologies, I didn't read all of your post Try setting a UDL password and using that, when I tried that, it does sort of work but usually results in crashing my ComIP module causing a com port fault Ok... using the UDL password connects but it makes the Com-IP fault all the time. Pity there is no fix for such a useful tool. Quote Link to comment Share on other sites More sharing options...
breff Posted April 2, 2011 Share Posted April 2, 2011 (edited) to switch from one option to another you must close the existing option by clicking the underlined close at the bottom So there was nothing wrong with the upload it seems Edited April 2, 2011 by breff Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
jamesg669 Posted May 18, 2011 Share Posted May 18, 2011 Hi, has anyone yet had any luck writing Java code to connect to the ComIP module, I am able to connect to the module but have not yet worked out how to send a receive meaningful messages. In addition i notice you are able to telnet to port 9999 of the comip, but it requires a password, i have tried all the usual defaults and the passwords for UDL, engineering code etc... but no luck, any ideas? Any info appreciated, Thanks, J Quote Link to comment Share on other sites More sharing options...
skywalker Posted October 17, 2013 Share Posted October 17, 2013 bump Quote Link to comment Share on other sites More sharing options...
