October 28, 201015 yr comment_255972 Could be a revitilised PSU along with a reboot did the trick. After all, that was mentioned before. I must have missed that ! Been going for 5 hrs without a problem so far. I'll check the pc cards as well. Thanks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-255972 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 28, 201015 yr comment_255975 I'd do that if it falls over again, otherwise don't fix what ain't broke . Always worth having it supplied from a small ups, this stops short power outs from causing glitches also remove most mains power born problems. Arfur If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-255975 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 28, 201015 yr comment_256049 I'd do that if it falls over again, otherwise don't fix what ain't broke . Always worth having it supplied from a small ups, this stops short power outs from causing glitches also remove most mains power born problems. Arfur The first thing the technician told me was to get a ups , Ill go and get one asap. This morning still working fine ! Thanks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-256049 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 29, 201015 yr comment_256078 The first thing the technician told me was to get a ups , Ill go and get one asap. This morning still working fine ! Thanks. I don't mean to make things more complicated but if you want to do things right do a little research on the UPS. This is what you should look out for: - Make sure the UPS has powerfail recovery, some UPS (especially cheaper ones) do not automatically supply power when the mains comes back on. The result is your DVR could be down all night (until you come in and turn the UPS back on) for a 1 hour power outage. - It is quite possible that the Intellex has the capability to connect to the UPS, if so the Intellex can monitor the charge left in the UPS and shutdown in a controlled manner rather than a hard shutdown. If the intellex has this capability, it may only be compatible with certain UPS models. Its up to you if you wish to look into any of the above but at least you know before you buy Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-256078 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 29, 201015 yr comment_256079 Id recommend apc ups's securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-256079 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 3, 201015 yr comment_256591 Thank you all. So far no problems , I hope this problem I had might help other users in case it happens to them too. Funny how the story ended. Reset ...and voila' ! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-256591 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 3, 201015 yr comment_256596 Not really, we see this all the time after flaffing about. Rather not reboot everything but when needs must and all that Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-256596 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 22, 20169 yr comment_447546 If anyone has the solution to this problem please PM or email me I am using a intellex dvms and I lost the admin code if anyone can find it or know how to get around it pm me or email me please my email (not allowed in a post) most appreciated Edited June 22, 20169 yr by MrHappy removed email Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29152-intellex-dvms/page/4/#findComment-447546 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
