john@total Posted August 14, 2008 Share Posted August 14, 2008 Hi Has anybody ever fitted an intruder system on a catermaran before. Just received a spec through what the owner requires Panel should be 9 zones User to be able to set circuits indipendantly 3 types of alarm: 1/ Siren, floodlights & sms message 2/ floodlights 3/ bells only floodlights should be stainless steel sensors should look smart and small setting is to be simple sensors can be wired or wireless As this is something i have never quoted before, so i would like to hear from anyone who has installed systems in a marine enviroment. If the tender is acpected then the job is for the 3rd week in september and the install will take place in Genoa Italy. Link to comment Share on other sites More sharing options...
arfur mo Posted August 14, 2008 Share Posted August 14, 2008 HiHas anybody ever fitted an intruder system on a catermaran before. Just received a spec through what the owner requires Panel should be 9 zones User to be able to set circuits indipendantly 3 types of alarm: 1/ Siren, floodlights & sms message 2/ floodlights 3/ bells only floodlights should be stainless steel sensors should look smart and small setting is to be simple sensors can be wired or wireless As this is something i have never quoted before, so i would like to hear from anyone who has installed systems in a marine enviroment. If the tender is acpected then the job is for the 3rd week in september and the install will take place in Genoa Italy. not actually installed one on a boat that was fre standing, but have quoted a few, 1st thing to point out is sea water area's are highly corrosive enviorments, as example i have door entry systems with front panels facing the sea on blocks of flats, that suffer far more failures to voice units and buttons, even VR ones due to corrosion than anywhere else - and thats on land, so what ever you fit needs to be carefully sealed. your power source is the next big issue, you might be able to use solar panel/s, but you will need to us very low power consumption kit so radio detectors and contacts (i'll quote to do the servicing 1 x pa in august if you like ), and caravan systems come to mind, i don't know of any 9 zone caravan alarms though. gsm dialer might be a good option to offer, as on alarm out it could then be used to trigger the light remotely. you have to be careful here as a flat battery due to false alarms would not be best pleasing, yet i wonder the value of a 'siren only' when the boat is mored off shore, but you could fit a water proof master blaster as an outboard so the boat could 'run away' from the thieves . might be an idea to contact a few boat builders and chandlers to ask for suppliers of this type of kit, and also about the lamp. regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
james.wilson Posted August 14, 2008 Share Posted August 14, 2008 We have done some systems on larger ships, and the only thing we have found to be stable are active beams. Any movement sensor will false alarm, and door contacts are a nightmare to fit. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
leesutton Posted August 14, 2008 Share Posted August 14, 2008 Theres a manufacturer down south called dolphin security and they specialize in marine systems. hope this helps. lee Lee Sutton E-Mail: leesutton@centurianfire.co.uk Website: www.centurianfire.co.uk Phone: 0845 094 9870 CENTURIAN FIRE & SECURITY (part of centurian group limited) Link to comment Share on other sites More sharing options...
