Nova-Security Posted July 28, 2006 Share Posted July 28, 2006 Some receivers get over-busy and with intermittent faults like this my money is on this type of failure at the ARC. Mines on they use call routing and its nothing to do with the ARC www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Brian c Posted July 28, 2006 Share Posted July 28, 2006 Doesn't that stop it signalling alltogether though, if it needs the magic number? Mines on they use call routing and its nothing to do with the ARC How much you betting? A weeks holiday?! If you don't know......ask. Link to comment Share on other sites More sharing options...
Guest rjbsec Posted July 28, 2006 Share Posted July 28, 2006 Doesn't that stop it signalling alltogether though, if it needs the magic number? My thinking too. Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2006 Share Posted July 28, 2006 ........Of the 400 stores - around 40 are high street locations that have been around donkeys years. They are fitted with differing alarm panels, and are maintained by one of two different providers (both big names), and are monitored by one central ARC........... i reckon whistle guessed right Yet - randomly, and not all stores, and never the same stores on the same night - from time to time - the high street stores keep getting these phone calls from the ARC saying that close signal has not been received. It's completely random. We have days where all alarms set - we have days where a number don't send the 'close' signal. Some happen a couple of times a week - others happen once a fortnight. It's all over the country - and not just in one geographical area. don't tell me the stores work the same hours? how many lines you got? what receivers are you using? what software is the arc running? what communicators / modems are affected? what format is being used? apart from the top advice you've already had.................. set up the problem sites with two accounts your arc being key1 for arc two no close you ring them up to see if theve got a close? Link to comment Share on other sites More sharing options...
Nova-Security Posted July 28, 2006 Share Posted July 28, 2006 Doesn't that stop it signalling alltogether though, if it needs the magic number?How much you betting? A weeks holiday?! Nope, remember the high street shop you went to in Bury, where they where getting random open and closes They had call routing and the magic number sorted it So do you owe me a weeks holiday then, now you remember that shop we had the same problem with about 3months ago ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2006 Share Posted July 28, 2006 Yes they did - and yes it did.... i thought this would mean NO FTC (so why are everyone still stuck with that??).. anyhow - silly enough - i have similar problem here too. as far as i have been able to investigate my bet is on faulty receiver card that gives ack to panel but doesn't send anything through.. Link to comment Share on other sites More sharing options...
Brian c Posted July 28, 2006 Share Posted July 28, 2006 Nope, remember the high street shop you went to in Bury, where they where getting random open and closes They had call routing and the magic number sorted it So do you owe me a weeks holiday then, now you remember that shop we had the same problem with about 3months ago ? No. I remember the one I went to that wasn't sending o/c I think If you don't know......ask. Link to comment Share on other sites More sharing options...
Nova-Security Posted July 28, 2006 Share Posted July 28, 2006 No. I remember the one I went to that wasn't sending o/c I think It was sending them some times, and missing some Is that another weeks holiday iam due www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Brian c Posted July 28, 2006 Share Posted July 28, 2006 I wish my memory worked. I still reckon it's at the ARC end. If you don't know......ask. Link to comment Share on other sites More sharing options...
Nova-Security Posted July 28, 2006 Share Posted July 28, 2006 I wish my memory worked.I still reckon it's at the ARC end. Still reckon they are using call routing. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
