  1. Past hour
  2. Im not over keen on Sainsbury's their meal deals are deliberately confusing and nobody really likes Jamie Oliver with his waste the difference
  3. Today
  4. I judged it by what you eat on a daily basis, I was gonna say lidl but that just might have been ever so slightly foreign for you Dave
  5. Yesterday
  6. probably all discounted & the bloke who fitted is long retired or dead ? I like to think on the bright side
  7. I'd assume the fire doors & shoplifters ? But could be anything ? Sainsbury's is my preferred super market. then maybe Tesco ? Morrison's is pretty much - unwashed scum of the earth which makes an Asda look posh, My local Waitrose has an lovely "drain" smell about it, go in your workwear & security follows you I have a nice Heron's & also Heron's on the council estates...these along with farmfoods are brilliant. Go in the store in suit & says please & thank to checkout person & they think you must be a mystery shopper or from snooping from head office !
  8. Last week
  9. Does this not mean it reaches grade 3 requirements??? Although this is the sc105
  10. Is product available that is graded? If yes then you cant use, if no then it would yes Also there may not be a EN for that detector (id of thought it would fall under shock though)
  11. Oh I thought it was french lol
  12. They have some German VDS approvals but nothing which is UK specific.
  13. Chatgpt makes things up maybe Red intruder activation White pulsing deterrent light at night or when set Yellow indicator for fault What you think ? Chatblag?
  14. I would have thought they have some other kind of certification as opposed to stating they are grade 2/3
  15. Hi All, Bit of a compliance question here... We have been asked to fit Honeywell SC100 seismic sensors on a G3 system however the SC100's dont seem to bear any security grading. I know these are used industry wide and they are "the right" bits of kit for the job but how can they be fitted on a graded system without affecting the overall system grading?
  16. Morrisons is a bit posh for up here... Heron or Farmfoods maybe?
  17. I wonder what the traffic lights are all about. Never had you down as a Habitat shopper, always imagined you shopping in Morrisons
  18. Every time I see this I think must share it as somewhere
  19. 4700(496383_iss_1).pd Gotham postcode ?? oh noun..... attached appear to be from the grey workshop manual.... download it quick before the evil mod team remove it
  20. Ankle tag & 7too7 curfew ? Nah am living in a abandoned hospital my mate bought though Its so old the only manuals i can find are in French
  21. Ankle tag & 7too7 curfew ? is it listed in the grey "workshop" manual, as the product is much older than pdf files ?
  22. Earlier
  23. I'm pretty sure the guy has tried this but I'll get my mate to have a look with me and give it a try myself. Thank you for your help.
  24. To put that in english: Type the user code that works, press no till you get to CD press Yes then enter the four digits you want to use, and again a second time to confirm
  25. this shows the process
  26. Both the engineers code and the default user code allow me to access the control panel (the box that enables you to activate / deactivate the alarm) however as far as I can tell by the user manual I have, neither codes allow me to change the alarm set / unset code which is personal to myself. It must be able to be changed as it was changed when the system was installed in the property.
  27. If you have no code that works then you wont be able to change the code. If you could change the code without knowing what it is to begin with, anyone could just change your code while your back is turned.
  28. I have used the default user code and I don't get anywhere. There seems to be no steps in the manual to personalise your alarm code.
