Guest LED Posted September 7, 2005 Share Posted September 7, 2005 I have connected 2 oddassay 1 bell boxes together, but after trying to enter the unique hold off system it did,nt seem to work. Is it because I have linked out the tamper in the sterling 10 control pannel after rectifying a previous fault of a temper indicating on arming the pannel. Please help. Link to comment Share on other sites More sharing options...
Guest Posted September 7, 2005 Share Posted September 7, 2005 Did it ever work? Between this and your other post it sounds like the tamper circuit has never been closed properly. Link to comment Share on other sites More sharing options...
Nova-Security Posted September 7, 2005 Share Posted September 7, 2005 I thought the unique hold off only worked with Texecom panels, do you mean when you put the panel in to engineers the bells are in engineer mode. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
dpaengineer Posted September 7, 2005 Share Posted September 7, 2005 Texecoms engineers hold can only be activated by a texecom panel. Its not the same as simply entering engineers mode on a panel. Looking at your last post too. I would say that the wiring for the 2 bells is not correct. There shouldn't be an open tamper loop, and linking it out is no fix. Think about it. If the tamper is wired wrong, then something else must also be wired wrong. 1 wire alone can not be the wrong way round if u get my drift. I would check the wiring out on both boxes. Even post the connections on here and some body may spot the mistake. Trade Member Link to comment Share on other sites More sharing options...
Guest Posted September 7, 2005 Share Posted September 7, 2005 I thought the unique hold off only worked with Texecom panels, 67352[/snapback] It works automatically with Texecom panels but with others you can do it manually, although I've never tried it. Link to comment Share on other sites More sharing options...
Paul P Posted September 7, 2005 Share Posted September 7, 2005 It works automatically with Texecom panels but with others you can do it manually, although I've never tried it. 67357[/snapback] Yep always did it maunally, sometimes took two attempts! Trade Member Link to comment Share on other sites More sharing options...
Guest Posted September 7, 2005 Share Posted September 7, 2005 although now on the latest firmware version this feature has been removed from being automatic, to being a function in the test menu. 67359[/snapback] I nearly mentioned that but couldn't remember if it was just something that got mentioned or whether it actually got out into the next release of firmware. Link to comment Share on other sites More sharing options...
Guest LED Posted September 7, 2005 Share Posted September 7, 2005 Thanks everone I do have a pyronix conquerer pannel and this connected to a texecom odyssey 1 and it works fine by instigating the strobe 3 times, I wonder if I am going over the magic 30 seconds. Any suggestons Link to comment Share on other sites More sharing options...
Guest Posted September 7, 2005 Share Posted September 7, 2005 No, it's because there is a tamper fault in the bell tamper circuit. Link to comment Share on other sites More sharing options...
Guest LED Posted September 8, 2005 Share Posted September 8, 2005 Thanks for your postings Heres the wiring 12+ Hold off pannel to bell 1 to bell 2 12+ supply 0v - Pannel to bell 1 to bell 2 0v supply Bell trigger Pannel to bell 1 to bell 2 bell trigger Bell Tamper Pannel to bell 1 no connection to Bell 2 Stobe- Pannel to bell 1 to bell 2 strobe Take wire out of terminal sw2 out of bell 1 link spare cable from bell 2 to it and connect to terminal sw1 in bell 2 There is only one cable running back to the control pannel. The led lights do indicate everything is OK alternating slowly as to fast when engineer hold off is to be re instigated after 2 minutes. Can anyone find anything wrong with the wiring I foolowed texecom 2 bell wiring diagram Thanks folks Link to comment Share on other sites More sharing options...
