November 14Nov 14 comment_532758 Do I just stick them in, or do I have to do anything at the panel such as re-registering the sensors?Panel is an SW-1070. Edited November 14Nov 14 by Eugene's DIY Den Talking Tools, a Facebook group for discussing anything tool/DIY related. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47576-replacing-batteries-in-hkc-sensors/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 14Nov 14 Author comment_532759 That's what I did, no issues. I didn't replace them all as only one sensor was complaining. Does an internal sounder also notify the panel when its battery is low? Its battery status isn't listed in RF devices. Talking Tools, a Facebook group for discussing anything tool/DIY related. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47576-replacing-batteries-in-hkc-sensors/#findComment-532759 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 14Nov 14 comment_532760 We change battery routinely so never seen a sounder low batt. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47576-replacing-batteries-in-hkc-sensors/#findComment-532760 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 14Nov 14 comment_532761 No re-registering needed. The sensor keeps its ID, so it is just a battery swap. The only catch is that opening the cover trips the sensor tamper, so either do it in engineer mode or expect a tamper alarm that you clear with your code once the lid is back on. If a tamper fault keeps showing after that, the lid or tamper switch usually isn't seated properly.On the sounder, rather than waiting for a warning, if you have engineer access have a look at the RF device status in the devices menu. On most SecureWave panels it shows signal strength and battery level for each wireless device, so you can see which ones are actually getting low and change them in one go. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47576-replacing-batteries-in-hkc-sensors/#findComment-532761 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
