virdi Posted February 17 Author Share Posted February 17 It's fixed! - It was a blown fuse in the end! When I first tested the fuses - I did not remove them from the panel!! (YES! I am a doughnut!) I think ..I caused the fuse to blow - as I cut the bell wire - whilst the system was still powered on. Thank you again all! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47441-scantronic-9651-showing-aux-dc-fail/page/2/#findComment-531698 Share on other sites More sharing options...
al-yeti Posted February 17 Share Posted February 17 1 hour ago, virdi said: It's fixed! - It was a blown fuse in the end! When I first tested the fuses - I did not remove them from the panel!! (YES! I am a doughnut!) I think ..I caused the fuse to blow - as I cut the bell wire - whilst the system was still powered on. Thank you again all! Good job And probably needed the battery anyway 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47441-scantronic-9651-showing-aux-dc-fail/page/2/#findComment-531700 Share on other sites More sharing options...
virdi Posted February 17 Author Share Posted February 17 Thank you! yes and battery replaced. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47441-scantronic-9651-showing-aux-dc-fail/page/2/#findComment-531701 Share on other sites More sharing options...
