robertjan Posted January 18 Share Posted January 18 Goodevening, I could use some help setting up a Betty Siren (see datasheet attached) on my GD48. My setup is as follows; MK7, Selfmon LCE-K3 and RF Portal C079-2 on the Bus, connected to several DO8M and IR8M sensors. Everything works fine, except my siren, I don't get it working. I connected (+) (blue) to AUX3 and (-) (blue/white) 1001, see attached. In my system 10001 output set to Siren V and neg. Tamper from the siren (white/green and green tot AuxTEMP and GND No sound of the siren when zones are violated. All zones are labelled to intruder and Siren also. Can someone help me out? Thanks so much! Kind regards, Robert Jan Datasheet_Betty_sirene.pdf 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/ Share on other sites More sharing options...
al-yeti Posted January 18 Share Posted January 18 1 hour ago, robertjan said: Goodevening, I could use some help setting up a Betty Siren (see datasheet attached) on my GD48. My setup is as follows; MK7, Selfmon LCE-K3 and RF Portal C079-2 on the Bus, connected to several DO8M and IR8M sensors. Everything works fine, except my siren, I don't get it working. I connected (+) (blue) to AUX3 and (-) (blue/white) 1001, see attached. In my system 10001 output set to Siren V and neg. Tamper from the siren (white/green and green tot AuxTEMP and GND No sound of the siren when zones are violated. All zones are labelled to intruder and Siren also. Can someone help me out? Thanks so much! Kind regards, Robert Jan Datasheet_Betty_sirene.pdf 155.04 kB · 0 downloads Are you sure the output is set to the word siren can you check exactly what it is? And you are on Rio one not zero, on the right output Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531537 Share on other sites More sharing options...
james.wilson Posted January 18 Share Posted January 18 Try putting the trigger to hard voltage. If it doesn't trigger isn't an output issue securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531540 Share on other sites More sharing options...
al-yeti Posted January 19 Share Posted January 19 12 hours ago, james.wilson said: Try putting the trigger to hard voltage. If it doesn't trigger isn't an output issue You mean the bell itself right Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531547 Share on other sites More sharing options...
james.wilson Posted January 19 Share Posted January 19 Yeah securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531548 Share on other sites More sharing options...
robertjan Posted January 19 Author Share Posted January 19 Hi, thanks, I changed some things, current setting: Positive wire of the siren on aux 3 Negative wire of the siren on RIO 1 1 See attached. In the menu: 52: zone function is Inbraak (burglary) 53. 1021 Siren V POS 53.1 =Siren If I set the alarm it detects Inbraak(burglary) but the siren gives no sound. Any Thoughts? Kind regards, Robert-Jan Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531549 Share on other sites More sharing options...
al-yeti Posted January 19 Share Posted January 19 34 minutes ago, robertjan said: Hi, thanks, I changed some things, current setting: Positive wire of the siren on aux 3 Negative wire of the siren on RIO 1 1 See attached. In the menu: 52: zone function is Inbraak (burglary) 53. 1021 Siren V POS 53.1 =Siren If I set the alarm it detects Inbraak(burglary) but the siren gives no sound. Any Thoughts? Kind regards, Robert-Jan As jw suggested if you disconnect the trigger from Rio connection 1 and force to ground , does the bell ring? If it does then you have programming issue Try Rio 0 position 1 without changing it's settings after that maybe Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531550 Share on other sites More sharing options...
robertjan Posted January 19 Author Share Posted January 19 It works! I found cable which was broken... thnx for all the help! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47433-galaxy-dimension-48-siren-issue/#findComment-531552 Share on other sites More sharing options...
