Galaxy Dimension 48 Siren issue
Goodevening,
I could use some help setting up a Betty Siren (see datasheet attached) on my GD48. My setup is as follows;
MK7, Selfmon LCE-K3 and RF Portal C079-2 on the Bus, connected to several DO8M and IR8M sensors.
Everything works fine, except my siren, I don't get it working.
I connected (+) (blue) to AUX3 and (-) (blue/white) 1001, see attached. In my system 10001 output set to Siren V and neg.
Tamper from the siren (white/green and green tot AuxTEMP and GND
No sound of the siren when zones are violated. All zones are labelled to intruder and Siren also.
Can someone help me out? Thanks so much!
Kind regards,
Robert Jan
Datasheet_Betty_sirene.pdf
1 hour ago, robertjan said:
Goodevening,
Kind regards,
Robert Jan
Are you sure the output is set to the word siren can you check exactly what it is?
And you are on Rio one not zero, on the right output
Try putting the trigger to hard voltage. If it doesn't trigger isn't an output issue
You mean the bell itself right
Hi, thanks, I changed some things, current setting:
Positive wire of the siren on aux 3
Negative wire of the siren on RIO 1 1
See attached.
In the menu:
52: zone function is Inbraak (burglary)
53. 1021 Siren V POS
53.1 =Siren
If I set the alarm it detects Inbraak(burglary) but the siren gives no sound.
Any Thoughts?
Kind regards,
Robert-Jan
See attached.
In the menu:
53.1 =Siren
Any Thoughts?
Kind regards,
Robert-Jan
As jw suggested if you disconnect the trigger from Rio connection 1 and force to ground , does the bell ring? If it does then you have programming issue
Try Rio 0 position 1 without changing it's settings after that maybe
